How to fillet top and side edge?
Hi
I want to fillet a cube as picture below:
I don't intent to fillet all edge of cube.
I can not choose many edge. I fillet 1 edge then select other. they will be error.
4 REPLIES 4
You need to use the 'sub-element' selection option.
In the selection arrow tool you can change it to this (white arrow) or you can hold CTRL+SHIFT to temporarily switch to sub-element selection.
Then select just the edges you want and chamfer them - but choose the option to 'apply to all' otherwise only the last edge you selected will be changed.
You must do them all at once otherwise if one edge is chamfered, it will not be possible to chamfer another adjoining edge.
You will have to edit out the existing chamfers, select all the required edges again and apply the chamfer to all of those edges at once.
Hi Barry Kelly
I can select multi edges by Ctrl + Shift. But when I click fillet they only fillet edge where I click.
Can you try it?
Hi
I did it. It work if I select fillet tool in Menu bar.
Thank Barry Kelly
If you use the pet palette option, be sure to select the 'Apply To All Edges' option.
This will apply to all the edges you have selected.
