How to get coordinates of the section/elevation story line?
I want to script new Story Marker with additional line parallel to the default story level line. But I have no clue where can I get length or coordinates of the start and end of section/elevation story line.
I have created new object of subtype Story Marker and don't see any parameters I could use there. I thought of using command LIBRARYGLOBAL (from page 291 in 05 GDL Reference Guide) to access parameters from other macro that contains this information.
Probably this information could be storied in Section-Elevation Marker Macro. I saw some people suggested in related topics that such build-in macros could be found in
Graphisoft/Archicad/Support/ARCHICADResources.framework/rfs/
but I don't see rsf folder on my Mac. I turned on option to see hidden files.
So do you know how can I get to know what parameters are in Section-Elevation Marker Macro or how to find this macro?
Or maybe there is other way around it?
Thank you,
Maciek
0 REPLIES 0
Learn and get certified!
