SOLVED!
How to not display 2D hotspots in 3D view?
muril00ng
Hello all,
I'm creating an object and I've set hotspots in 2D script, but object insists in showing them in 3D Views. I've tried to apply the option "Ac_show2Dhotspotin3D" in different instancies, but it simply doesn't work.
Any suggestions to avoid the issue?
____________________________________
Murilo Noleto
http://www.kilobim.com.br/
AC 12 - 27 | Win 10 | 16GB | NVidia GTX 1050Ti | AMD Ryzen 7 1700X
1 ACCEPTED SOLUTION
Solution
I don't know if it's the only way to do it but if you actually define 3d hotspots (in the 3d script), even as few as just one, then I believe your issue will be solved.
Doug
3 REPLIES 3
Solution
Doug
muril00ng
Issue solved!
Thanks Doug.
Murilo Noleto
Glad I could help.
Doug
Learn and get certified!
