How to remove line between connected door and window.
I wonder is there a way to remove this thick line between door and window? The objects are separate, because I can't create door with triple window using one library object. This line bugs me off as I have this all over my project and the only solution I know is to use 2d drafting and mask the issue, but it's not ideal. Also I don't want to change wall pen.
2 REPLIES 2
Eduardo Rolon
In the Door (and Window) settings there should be an option for "ganging" which controls the wall line between objects
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Thanks for reply!!! Should have asked earlier. It's not perfect as I have to draw a thin line to close the sill, but it's much plausible. Thanks.
