2022-06-10 10:21 AM
Hi!
IN previous versions of Archicad, Ctrl + F just worked amazingly for me, to select "all windows", "all doors", "certain layers", or "furniture" and so on... NOW, that is a different story. It shows me some board to select what I already selected .... but it want me to confirm I guess? But then, I don't see there layers, dimensions (lets say I want to change all fonts for all dimensions...?) does not work. This tool I am attaching in pritscreen is completely useless for me. Is there any way, maybe that I overlooked, or unchecked... that I can select "all type" without going through this time wasting process?
Thank you!
Solved! Go to Solution.
2022-06-17 07:31 AM
For anyone in the future searching for the solution of this it is THIS!!!!
1. click on "pick up parameters" (toggle that looks like injection) to be specific.
2. click on the type of item and then CTRL+A.
3. that's it!
2022-06-10 11:55 AM - last edited on 2022-06-12 07:19 PM by Barry Kelly
By Ctrl+F you can select any element type not all elements even you can select by home storey criteria if you are in 3D and you can then store them under any name to retrieve any time, all that by Find & Select or Ctrl+F.
2022-06-10 12:58 PM
Does not work
2022-06-10 01:05 PM - last edited on 2022-06-12 07:19 PM by Barry Kelly
Sorry, what actually doesn’t work?
Find & Select via Edit menu or Ctrl+F via keyboard Shortcut or the relevant icon in Edit Toolbar, or the dialogue appears but can’t select what you want?
2022-06-10 01:10 PM
As mentioned before, Ctrl+F does not work. it bring the toolbar which I can't care less to use. Before, If I click windows + Ctrl + F = it would select only windows. I can't work with tool bar like this and do all manually. Especially many things aren't even in options, or have a name that I don't recognize what the option would be. So my point was, except the toolbar that appear (printscreen), is there other option to select all windows/funriture/dimensions/etc.?
2022-06-10 02:27 PM
So you should read carefully what @Ransom Ratcliff mentioned in his post, I hope it helps.
2022-06-10 03:03 PM
Ok I will go through it again.😂 I just thought the answer for this easy-to-do in other softwares (all?) would be more simplicit I guess 😁😁😁 but ok I will try again.
2022-06-10 03:27 PM
It never worked that way. It pretty much works the way it has for 20 years, so it is hard to understand what you think 'broke'. Ransom has given the best method - since forever - for selecting all windows, etc. Otherwise, ctrl-F lets you either fill in the criteria (and save them for later) and do a find... or "pick up" the type and parameters of a selected element and find everything else like it (with matching parameters...that you add one by one to narrow down the selection).
Read Ransom's post here ... and read the User Manual for how to use Find & Select. You must be thinking of some other software if you think something has changed...
2022-06-10 05:07 PM
I have been working with Archicad 6 years, with 2 years break and I reminder the function that I could select by a shortcut (I believe it was ctrl+f) All category - whether it was windows, furniture.. Or something.... so for example, if I get doors height wrong at the beginning, and it changes into different size, then I don't have to click on each door..... like 1000 doors? I would not like that? 😄 So this is the tool I mentioned, if that was not clear from me.
2022-06-10 12:55 PM
Also, don't forget the elegant refinements on the universal "Select All" command that Graphisoft implemented in a previous century. 😀
In most applications, you simply use Ctrl+A (Windows) Cmd+A (Mac) to select everything. In Archicad, that is how it works too, if you have the Arrow Tool active. But, Graphisoft took this simple standard and turned it into something far more powerful without adding a dialog, menu, or complex steps!
Learning to avoid the Arrow Tool for most selection operations is often one of those habits that former Revit users have the most trouble with as new Archicad users.
But it's worth it! 😀
2022-06-10 05:10 PM - edited 2022-06-10 05:16 PM
Hi Ramson,
I went through the full reply step by step and no luck. :((( Whether I do ctrl+A OR ctrl+F before or after, or different arrows... it just does not work....ctrl+a whether select full floor plan (all in) or ctrl+f show the toolbox... whether I haven't explained myself well, or I don't know.
Please would any of you have maybe a video showing how to select only windows, or only doors, or only whatever from the floor plan so I can ALL edit at once, if size change without having to click on each window/door/ etc manually ? I really want to learn it.
2022-06-11 01:06 AM
https://youtu.be/zcgDu_wGQNA?t=227
First deselect everything, then select the tool of your choice, press Ctrl+A. only the elements of that tool are selected.
2022-06-17 07:31 AM
3. that's it!
2022-06-19 07:59 PM
You can do that, or just select the tool for the elements you want to select and then press CTRL+A as scottjm suggested.
2022-06-20 06:40 AM
How is that easier and different?? I don't actually understand what do you mean by "just select the tool for the elements" ...
2022-06-20 08:42 AM
You are saying (I believe), to select all walls you go to the pick up parameters tool (pipette), click that button (you can just hold the ALT key), click on the type of element you want to select (say a wall) and then press CTRL+A to select all walls.
Just activate the wall tool and press CTRL+A and it will do the same thing.
2022-06-20 08:47 AM
I see what are you saying! I tried all of that and beyond to the point someone would describe me as ADD 😁 - but for some reason did not work. I don’t know if it is because MacBook user but really did not work.
2022-06-20 08:51 AM
The keyboard shortcuts I mention are for Windows.
I have no idea what they are on a Mac - whether they are the same of different, but they are there.
