Design forum
How to set different wall closure thickness?
William Yan
Hi guys, I met a problem. I can't set different thickness of the wall closure. As shown in pic below, How can I set thickness of "b" not equal to "a"? Thank you !
AC 25 5010 CHI, Windows 10
Andrii Levko
I do it like this
This the same thickness
Sorry for language, but in this moment I have only polish version.
Andrii
AC 8.1 - 25 INT/POL 5010
11 REPLIES 11
Lee Hankins
I'd have to have a dig around in the settings but I am sure you can achieve this.
Lee Hankins
ArchiCAD 4.5 - ARCHICAD 26UKI Intel 3010 and Apple Silicon
macOS Monterey (12.5)
Hoping you can help me out. I tried the whole afternoon.😂
William Yan
it goes out the wall side not goes init goes out the wall side not goes ings videosgs videoswhy it goes in the wall not out the wall sidewhy it goes in the wall not out the wall side
Lee Hankins
I need to open an old project and see how I did it. I won't be able to do it until later today. If you haven't heard back tomorrow, chase me.
Lee Hankins
Thank you Lee! And Dear Andrii helped me out. Haha!
Andrii Levko
I do it like this
Andrii
New problem here! How to set the closure line thickness same as the outer line of the wall? pics in the following reply.
William Yan
WOW THANK YOU! You saved me Andrii! The secret is to use the wall reveal along with the custom closure and it's thickness must equal to the custom thickness!😀
William Yan
Dear Andrii, New problem here! How to set the closure line thickness same as the outer line of the wall?  skin line 1 and 2 should be the same, and 3 is the thick wall cutline
Hi William,
This is really a problem because even in the Archicad Channel video (as you showed above)  there are lines of varying thickness as you may have noticed.
I have some workaround for myself, but I don't know if it will suit you because it's a bit complicated.
But looks like the picture below.
Workaround is based on the following:
I turn off Skin End Line only for core wall material.
Then I add 0.1mm thick air space on the inside of the composite wall and wrap it to the outer edge of the window in Window Settings Dialog>>Wall Closure>>Inside Face, creating a Skin End Line where I need it.
I don't know if such a workaround will be useful for you, but sometimes it helps me for some cases.
Andrii
Thank you Andrii! 🤝
