How to set different wall closure thickness?
William Yan
Hi guys, I met a problem. I can't set different thickness of the wall closure. As shown in pic below, How can I set thickness of "b" not equal to "a"? Thank you !
AC 26 5002 CHI, Windows 10
Andrii Levko
I do it like this
This the same thickness
Sorry for language, but in this moment I have only polish version.
Andrii
AC 8.1 - 27 INT/POL 3001
Win11 | Ryzen 5600 | 16 GB | GTX 1650
11 REPLIES 11
I'd have to have a dig around in the settings but I am sure you can achieve this.
Lee Hankins
ArchiCAD 4.5 - Archicad 27UKI Apple Silicon 27.1.1
macOS Sonoma (14.2)
Hoping you can help me out. I tried the whole afternoon.😂
William Yan
it goes out the wall side not goes init goes out the wall side not goes ings videosgs videoswhy it goes in the wall not out the wall sidewhy it goes in the wall not out the wall side
I need to open an old project and see how I did it. I won't be able to do it until later today. If you haven't heard back tomorrow, chase me.
Lee Hankins
macOS Sonoma (14.2)
Andrii Levko
I do it like this
Andrii
William Yan
WOW THANK YOU! You saved me Andrii! The secret is to use the wall reveal along with the custom closure and it's thickness must equal to the custom thickness!😀
Thank you Lee! And Dear Andrii helped me out. Haha!
New problem here! How to set the closure line thickness same as the outer line of the wall? pics in the following reply.
William Yan
Dear Andrii, New problem here! How to set the closure line thickness same as the outer line of the wall?  skin line 1 and 2 should be the same, and 3 is the thick wall cutline
