How to switch to opening side of a combi commercial door
Hello, I'm going to reproduce an existing school in Archicad. I have un metal door with a side-window. I choose to use the Combi commercial door but I have a problem. I can not set the opening side without changing also the side of the window. I would like to put the side window and the hinge on the left side. Currently the window is on the left and the hinges on the right.
Tank-you
1 REPLY 1
I am not sure what object you are using, but do you have a different object with the window on the other side?
If not is there a parameter in the object that allows you to have the window on the other side?
Learn and get certified!
