How to take effect only in one end of rail
Daniel_He
For instance, I only want to make 90digree in one end and keep the straight in another end. But I didn't find way to setup
Daniel.He
ArchiCAD 25 3011 USA - Windows 11 Home 64x
DESKTOP 12600KF 64G RAM 3070 GPU
David Maudlin
Daniel_He:
I don't think this can be done during setup. Set the rail end parameters for one End, then after the railing is placed, select the railing, click the Edit button, then select the other End (on plan or 3D), open its settings and change them to suit.
You should add a Signature to your Profile (click the Profile button near the top of this page) with your Archicad version and operating system (see mine for an example) for more accurate help in this forum.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David Maudlin
Daniel_He:
David
Hi David, thanks for your support, it's done by your help. And I updated my signature
Daniel.He
Daniel.He:
Glad to help, thanks for adding your signature.
David
