How would you do this one?
Mats_Knutsson
Must work with schedule. I don't have an object that can do this. ANyone knows an object like this. Also glazing line in 2D needs to be manually on/off.
/Mats
AC 25 SWE Full
If you don't have a door/window builder add-on then maybe Library Part Maker might help.
I have not used it myself but my understanding is you create a custom opening from slabs (morphs?), but this standardises some of the display settings with other windows and doors.
https://www.nationalbimlibrary.com/library-part-maker
Mats_Knutsson
It's a last resort and quite a nice one. Done a few with the lib part manager but more pure custom windows/doors w individual 2D graphics which is kind of the same thing. The problem with custom objects is that they are not sketch friendly. It's not a strategic way to go when the sketching architects need to go to some of the more cad tech skilled people for a normal dw setup. GS need to rethink dw. It has been great (even magnificient ) in the past but it's getting old.
AC 25 SWE Full
I never tried this in that situation, but I have been looking for the opportunity: curtain wall tool can do anything. Whatever frame with whatever infill and openings.
So you could place a curtain wall on an empty opening. Empty opening with whatever ID that gets ignored by schedule. And you can make a schedule list anything, like 'all doors excluding those with this ID' + 'all curtain wall objects with ID containing whatever'. Both doors and curtain walls would get assigned a common set of properties, which are what you would list in schedules. Properties sound mysterious but it is really simple.
It is a dirty workaround, but quite powerful dirty workaround. If it does work, which I think it must.
I wish we had 'curtain wall object' windows, so that they move together with walls etc.
Regarding hiding glazing line in plans, I can't think of anything except some other dirty workaround with pens and pen sets.
