I CANT MOVE OBJECTS MORE THAN 0,25 cm
hello everyone, i am in the middle of a school project and i am pretty desperate. i didn’t have this problem from the start it just kinda appeared, maybe i miss clicked something as i am very new to the program. every time i try and move an element ( text, object etc) it only moves to a specific place ( 0,25 cm to the left right top bottom). i can’t move an object, for example, like 0,03 cm to the right because it won’t let me. i have no precision. thx in advance
1 REPLY 1
You may have accidentally turned "snap" on. Can you only move in multiples of 0,25? If so SHIFT-S is the keyboard shortcut. It cycles thru' Off / grid snap / construction grid (larger distance) so try it a couple of times.
