2022-05-14 01:07 PM
I still can see the 3D Model and the Section I had made but that´s all. If I try to paste anything in the 2D window it says my clipboard is empty. I also cant add any walls whatsoever. I triedt copying the 3D Model and try adding it into a new file for example. Im pretty sure the floor plans are still there, cause I can switch from one to another and see how tall they are.
Some help would be appreciated.
Solved! Go to Solution.
2022-05-15 12:26 AM - edited 2022-05-15 12:27 AM
Are you looking at the correct storey in 2D?
Are all layers on?
Are renovation filters turned off?
Have you tried zoom to extents (fit to window)?
If you are in 25, you can select something in 3D, right click and say 'show selection in 2D'.
2022-05-14 04:29 PM
If you can see the model in the 3D window, then you can certainly obtain floor plans. Your 2D window settings including layer visibility, story and cut plane must not be set up properly.
You cannot copy from the 3D window and paste anywhere.
You can add walls in 2D or 3D with the Wall Tool. It is kind of impossible to not be able to add walls. You'll have to tell us more. 🙂
2022-05-14 04:43 PM
So basically while my 3D window is working fine, all I see is a blank white screen while on the 2D tab. I cant seem to zoom in or out of it and if I try inserting any line or wall, or basically any element it shows two small clouds instead of the arrow.
2022-05-14 06:46 PM
Screen shots would be an intense help
Also consider putting your machine specs and program version in your signature. This will always be helpful int the initial trouble shooting stages.
Are all layers on?
2022-05-15 03:22 AM
Yes, that did it for me. I just clicked on show selection in 2D and everything went back to normal. Thank you very much!
2022-05-25 11:59 PM
My question was resolved. Thank for your reply.
