2022-05-02 05:01 PM
2022-05-02 06:56 PM - edited 2022-05-02 08:45 PM
Because you are stretching the entire elements, you are effectively moving them, hence the labels will move as well.
I am not sure of a way around this.
Not even locking the label will make it stay put.
2022-05-02 07:29 PM
Thank you
there's no way
2022-05-05 04:02 PM
What I would do in such a case is I would remember the exact angle and distance that I moved my elements, then I would select the moved Labels and moved them back to their original place by the same distance in the opposite direction (angle).
