Design forum
If var contains?
JGoode
Is there a way to filter an array of text by searching if it contains a certain string?
eg
A - 1
A - 2
A - 3
B - 1
B - 2
B - 3
if *array* contains "A" then
Is this a possible thing to do?
ArchiCAD 23
Windows 10
8 REPLIES 8
Erwin Edel
Think you can find something like this at page 257 of the GDL reference guide, bit about VALUES{2} where they read string values from a text file and put them in an array.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
JGoode
The issue is that my list is going to be 2000+ values long so the ability to filter my array is essential. Is there a way to essentially search an array?
ArchiCAD 23
Windows 10
Erwin Edel
Doing this inside a GDL script sounds like a bad idea in terms of slow down inside ArchiCAD, I suspect.
Whatever 2D or 3D display information will eventually end up in the model might constantly look through that long list of things.
Is it an option to use properties, where I think you can import tabbed text files to fill property values, which you can then filter and schedule?
www.leloup.nl
Windows 10 Pro
JGoode
I thought the same thing. I also thought of the idea to split the files up into different sections but I am struggling to find any sort of way to filter through (if *file 1* = x then use *file 2*. I really don't think there is.
Would the using properties include creating a property object? I am not really familiar with creating properties using tabbed text files
ArchiCAD 23
Windows 10
JGoode
So as far as you know, there isn't a way of doing some sort of if string contains "x" then....?
ArchiCAD 23
Windows 10
JGoode
Another idea popped into my mind. Is there a way of creating an array based on another array which will only use certain strings?
So I have an array of 10 lines..
A-1, A-2, A-3, A-4, A-5, B-1, B-2, B-3, B-4, B-5
Can I makes those into 2 separate parameter arrays?
X = A-1 Y = B-1
A-2 B-2
A-3 B-3
A-4 B-4
A-5 B-5
ArchiCAD 23
Windows 10
Erwin Edel
I do not work with big arrays of information, but I remember from the ArchiCAD20 upgrade course I took, that you could use excel sheets and tabbed text files to import information to the then new Properties system. So if it is a matter of displaying and filtering external data, this sounds like an easier method.
www.leloup.nl
Windows 10 Pro
JGoode
It seems as though using properties isn't going to be an option for me.
What I really need is to be able to take a single array and split it into different parameters based on if it contains a certain string. Does anyone know if this is something that is possible to do?
ArchiCAD 23
Windows 10
Didn't find the answer? Start a new discussion
