There should be a command for 3DS import options as well as the command to actually import.
I don't have Archicad running at the moment so can't show you.
But in the options you can swap the X, Y & Z axis around - looks like you need to swap Y & Z.
Then import.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
