Incrementing a parameter by 1
Rob
Guys,
do you know a reliable way to increment a parameter by 1 in the parameter script? The problem is that the parameter script is run several times in order to recalculate all parameters... and that stuffs it up.
an example:
I want to increment (by one) the value of a parameter "A" each time you click the button on the custom UI tab.
Any thoughts?
::rk
This should do it.
	n = APPLICATION_QUERY ("PARAMETER_SCRIPT", "FIRSTOCCASION_IN_PROGRESS", isFirstRun)
	IF isFirstRun THEN
		A=A+1
	ELSE
		A=A
	ENDIF
4 REPLIES 4
This should do it.
	IF isFirstRun THEN
		A=A+1
	ELSE
		A=A
	ENDIF
Rob
Thanks mate!
What documentation did you get this from?
edited:
I see... Basic Library Documentation...
Anyway, thanks again.
::rk
Frank Beister
DirectLink
Thanks. Very helpful.
Nader Belal
Mentor
Thank you Michael
