There are several way to input from/output to files in GDL. You should check the GDL Reference Guide. You can work with TXT files, "Data Files" (you define the format in the file, but basically a text file), XML files.
After you input that data you can work with array and I guess you can narrow down the array into another array that contains only those items that fulfill your criteria.
