SOLVED!
Insert Object's Name as a parameter
Nader Belal
Mentor
Hi everyone,
I was wondering if there is a way to get object file name (without an extension) and insert it as a parameter using GDL script.
Example:
Filename: generic_object.gsm
param_name: generic_object
Thank you in advance
1 ACCEPTED SOLUTION
Solution
Nader Belal
Mentor
Thank you
2 REPLIES 2
JGoode
Try this:
rq = request ("name_of_macro", " ", file_name) 			!---Displays file name
nm = strstr(file_name, ".") 							!---Removes .GSM after file name
param_name = file_name
ArchiCAD 23
Windows 10
Solution
Nader Belal
Mentor
Thank you
Learn and get certified!
