2020-10-01 07:20 PM
Solved! Go to Solution.
2021-03-04 05:06 AM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-10-02 02:01 AM
2020-10-05 06:59 AM
Minh Nguyen
GRAPHISOFT
2020-10-11 04:44 PM
Braza wrote:
Is it a Complex Profile Wall? No, just pretty basic composite wall types.
Is your door frame thickness = wall thickness? Where is that setting? I don't see that.
Where is your Wall reference line? Center
2020-10-11 05:14 PM
2020-10-12 02:10 AM
2020-10-12 04:08 AM
Minh Nguyen
GRAPHISOFT
2020-10-13 05:23 PM
2020-10-13 05:24 PM
mnguyen wrote:Thank you Minh, I'll do that, not sure how the door got corrupted, but that does work.
Thanks for the file! After some tests, I believe that this particular door is corrupted somehow. I compared its settings with the neighboring one and found nothing special. If I use Parameter Transfer to pickup parameters from the "good" door and inject them to the "bad" door, it should jump to the wall's face.
Please let me know if it helps!
Thank you very much!
Best regards,
Minh
2020-10-13 06:33 PM
dcerezo wrote:
I don't have that option...that's weird.
2020-10-16 11:04 PM
2020-10-22 11:47 AM
2020-10-24 10:35 AM
2020-10-24 02:12 PM
2020-10-26 06:05 AM
Minh Nguyen
GRAPHISOFT
2020-10-28 03:57 PM
2020-10-30 08:19 AM
Minh Nguyen
GRAPHISOFT
2020-11-11 09:12 AM
2020-11-12 10:16 AM
How long does it usually take to fix something like this?Would like to know this answer as well. We are holding off migrating projects until this issue is resolved.
2020-11-15 03:46 PM
