jasonbakers wrote:
Is ArchiCAD the right software for this purpose? Or is there something else that suits our needs better?
I assume you are a reasonably competent computer user and have perhaps done some CAD before or are at least a bit 'left brained'? Otherwise, you should seek someone - even an architecture student - to assist you vs buying and learning a complex new program.
If DIY is your game plan, then at some level I agree with Brett about Chief Architect as being simple. But at another level, if the home has complex levels and trim and other custom details that you want to model, then ARCHICAD SOLO, which is about half the price of the professional version, might be worth looking at. Again, big learning curve that is difficult to do without at least a few days with an experienced user/tutor if you are new to CAD / 3D modeling.
If you have the skills, and are not overly concerned about money, then a way to get a head start on your home model is the Canvas app from Occipital which uses Occipital's Structure Sensor which you attach to an iPad:
https://canvas.io
The $ 399 price, assuming you already have a compatible iPad, lets you visually scan rooms - as seen in the videos there - via a 'painting' sweeping motion and then get 3D models for a small price per room, with an extra fee for the US-based Canvas staff to integrate all of the rooms into a single model.
My tests showed that measurements of dimensions for all elements of a room, including complex ceiling soffits, doors and windows, etc, were overall less than 0.5% ... but some individual errors of items less than 12 inches in width/height could be up to 8%. Where I had a major glitch in what I received, the Canvas people re-worked the model. If you've ever measured a room, or house, for an as-built, sizing and locating every window and door opening, cabinet, light switch, outlet, etc... it is an insane amount of measuring. So, to get a quick first draft with something like Canvas can be handy.
Output formats are .skp, .rvt., .dwg. .dae and .ifc. I imported SketchUp (.skp) models into ARCHICAD and found that they even modeled cabinetry and various pieces of furniture in each room - as separately grouped 'objects'. (This was before they offered IFC models - which I had suggested that they add their output list.)
For a quick 'as built' (your seeming initial goal) - or for context modeling for a remodel or expansion - this could be something to consider. If you want a precise model, you'll need to stretch/adjust things based on your own laser measure for the error rate of the sensor.
If you are a sophisticated computer user / engineer - then I would still recommend ARCHICAD for its modeling flexibility, ability to view the project in different ways, ability to handle remodels, visualization, ability to import/export in various formats, etc. But, again, you likely would want some in-person training for a couple of days (or more, depending on your personal skill set).
PS Disclaimer: My mention of Canvas above is just my personal experience after purchasing the hardware and scaning 6 or so rooms last year. I am not wearing my 'hat' as a moderator in this post.
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
