2022-09-26 10:32 AM
Is it possible to disable finalize/cancel when using 3d cutaway?
It's small, but I'm too lazy to click finalize all the time...
Solved! Go to Solution.
2022-09-26 11:48 AM
@LeeJaeYoung, don’t be lazy and click finalize pls pls cuz really you have to otherwise the model won’t be cut.
2022-09-26 12:11 PM
What does "pls pls cuz" mean? The translator couldn't translate it... ^^
I understand that your words have no way.
thank you ^^
2022-09-26 04:39 PM
Pls is short for please and cuz is short for because so I mean please Lee press finalize to get your model cut, thanks to you.
2022-09-26 06:53 PM
The annoying part is that the finalize button is not consistent in appearing in the same location, end up you still need to look for it. 😆
2022-09-27 01:40 AM
I had the same problem before, it's frustrating to hunt for the tiny button that keeps moving around the screen for every time.
Then by accident I found you can just hit Return / Enter instead of clicking Finalize – made my life a tiny bit easier.
2022-09-27 02:40 AM
Hi @david_skogvold, you said just hit Return / Enter, that means pressing Enter or what? Sorry need to understand.
2022-09-27 03:43 AM
thank you so much
2022-09-27 03:47 AM
Yes, after moving the cutting plane you can just hit Enter instead of clicking Finalize. (Just tested it in AC24, should work in other versions too..)
2022-09-27 11:33 AM
Great tip David, I was not aware of this neat little keyboard shortcut.
