Objects can't get information directly from other objects.
There is a way but it requires one object outputting information to an external text file and then the other objects reading that information back in - using the TEXT or DATA input/output.
I don't know how the Survey Point object works - whether it saves the co-ordinate information somewhere other than internally in the object.
I have never used this object.
If it does save the co-ordinate information somewhere, then your other objects could read this info in.
