SOLVED!
Is there a way to see the changes brought to an object in real time?
Say, if i placed a tree and go into the object selection settings to change its properties. Is there a way to see these changes before I click on OK all the time??
1 ACCEPTED SOLUTION
Solution
Hello Hishiiro,
You can preview your object at the top right of the parameter window. You have a plan view, an elevation view and an axonometric view.
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
"Quality is never an accident ; it's always the result of an intelligent effort" John Ruskin
2 REPLIES 2
Solution
Hello Hishiiro,
Christophe - FRANCE
Christophe wrote:
Hello Hishiiro,
Ah. I didnt know i could change that view. Thank you.
Learn and get certified!
