Design forum
Is there a way to transfer settings from one door object to another?
4hotshoes
The pick-up tool will suck all properties of a door. But what if I want all the same settings (trim, door leaf style, jamb, colors, threshold...) there are so many settings? What if I just want all the same settings, but I want a single and a double door to be exactly the same? Is there an easy way to do this with out having to make notes on a piece of paper and manually write them in for the next door object?
Todd Oeftger
Ligature Studio
AC23 and AC24 Mac MacBook Pro 15", 2019, 2.3 GHz i9, 32GB, Radeon Pro 560X 4GB, 500GB SSD, 32" Samsung Display (2560x1440)
1 ACCEPTED SOLUTION
Solution
Eduardo Rolon
The extremely old trick (Pre AC08 if I am correct) is:
1. Eyedrop the settings from the door without selecting it.
2. Open the "Door Settings Pane" either doble clicking the icon
3, Navigate to the door that you want (Double Door in this case)
DO NOT CLICK ON IT!
4. Inject (CMD+Opt in Mac) on the icon of the door
5. This transfers all settings from the previous door and then you can edit what is different
This trick is not limited only to doors
eduardo rolón AIA NCARB
Another of the forum moderators.
Macbook Pro M1 Max 64GB ram
OS X 10.XX latest
AC25 US/INT -> AC08
2 REPLIES 2
Solution
Eduardo Rolon
DO NOT CLICK ON IT!
OS X 10.XX latest
AC25 US/INT -> AC08
4hotshoes
THAT's what I am talkin about! Thanks! I love Archicad!
Todd Oeftger
Ligature Studio
Didn't find the answer? Start a new discussion
Labels
