2019-04-03 01:04 PM
2019-04-04 03:13 AM
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win10 | R5 2600 | 16GB | GTX1660 |
2019-04-04 09:18 AM
2019-04-04 04:50 PM
Lingwisyer wrote:
Materials are one of the many things in AC that are dictated by andIndex Number. If the material assigned to an index number is different from one file to another, then the appearance of an object that uses said material will look different. If need by, you can use the Attribute Managerto make files consistent by transferring attributes "by index".
In terms of the eye dropper, you may need to check it's settings.
Edit => Element Settings => Element Transfer Settings
In your image, is that two of the cabinet on the left, or is it a corner cabinet?
Ling.
2019-04-04 04:53 PM
Erwin wrote:
As a rule of thumb (assuming your template is based off the one that came shipped with your version of archicad and should work properly with that version's library): never change the 'stock' attributes, allways duplicate them, give them a clear new name and adjust those.
I've seen users change a white paint surface to green tiles or something to have those on the wall in a toilet and then act surprised when all their standard door frames look like green tiles.
Two seconds of extra work to create new attributes will save headaches later on.
2019-04-05 03:37 AM
2019-04-06 05:40 PM
Lingwisyer wrote:
Options => Element Attributes => Attribute Manager => Surfaces
On the right side, you will want to import your original template. Select all surfaces on the right side, and transfer them by index.
On Windows, it is located at:C:\Program Files\Graphisoft\ARCHICAD 22\Defaults\ARCHICAD
Ling.
