SOLVED!
JOINT WALLS NOT ABLE TO STRETCH, NODES ARE GREYED OUT. PLZ HELP
Hi all,
In Archicad 23 suddenly all my joint walls are unable to stretch. If its a single wall (not joined) it will be fine and can stretch with a black node but for some reason the joint walls nodes are grey.
My only options is to move, rotate, mirror, elevate and Multiple. I've attached an image for your reference.
Thanks!
1 ACCEPTED SOLUTION
Solution
Lingwisyer
Guru
Toggle grouping (alt + g)?
3 REPLIES 3
Solution
Lingwisyer
Guru
Or it could be that it is a module.
It worked, thank you so much
Learn and get certified!
