Project data & BIM
Layer kept wireframed when I change to 3D view with f3 shortcut key
Hi everyone,
I wonder why I keep having this weird problem with F3 shortcut key. But it does not show if I click on the 3D tab. It keeps repeating making my kitchen wireframe when I use shortcut key. In fact, it hides my other layer also. I find this layer combination hard to control. Anyone has any tips how to master this layer combinations?
2 REPLIES 2
Hi Abigaillow,
Open your layer settings (Ctrl +L) and check to see if that particular layer is set to wireframe. Your internal walls might have been accidentally set to wireframe view.
Each layer can be locked/unlocked , visible/invisible, solid/wireframe.
You can find more information here -
https://helpcenter.graphisoft.com/guides/archicad-21/archicad-21-reference-guide/user-interface-refe...
Jono
Link
Try assigning '3D Window with current settings' to your F3 shortcut.
Link.
