SOLVED!
Line/Spline/Poly Line object that displays it's length
I think there is a line tool something like that. Does anyone know where to get it ? Can't find mine anymore.
1 ACCEPTED SOLUTION
Solution
"Window > Palettes > Element Information" menu will display the "Element Information" Palette.
Then, if you select a placed Line, Polyline or Spline, the Element Information Palette will display its Length.
4 REPLIES 4
Solution
RandyC
Travel distance 21 2d
Travel Distance by Archiradar 2d - 3d
ArchiCAD 4.5 --- 27 , Win 10 , dual monitors, 64 gb ram,Nvidia GeforceRTX 2080 TI, I-9
Thanks Laszlo,
That works great for what I am doing. I needed a quick way to know the total length of my radiant heat tubing layout which I want to keep under 500' per circuit.
Erwin Edel
if you'd want to schedule it instead, you could magic wand a beam to the shape and schedule the reference line (set up a layer for it etc). It will even cut your slab if you are doing quantity take off for the amount of cement needed for the floor finish
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
