Low Voltage Cable Lighting
GJWarch
Has anyone found any Objects for low voltage cable lighting?
Thanks
1 REPLY 1
Hello GJWarch,
I use a classic spot. I propagate this object as a post of a railing. this makes it possible to size the distance between each occurrence or even to draw the wiring with the bottom rail of the guardrail. This low rail can be designed with a personalized profile.
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
"Quality is never an accident ; it's always the result of an intelligent effort" John Ruskin
