Design forum
MENUBAR/TOOLBAR GRAPHIC ERROR
ka
See graphic error on buttons in menubar and toolbar. There are horizontal or vertical lines running through buttons depending on their size and orientation. Happened after I updated project from 23 to 24, but may be unrelated. See images:
Monterey is not supported yet on AC24, you will find information about it on this page when it becomes available:
https://community.graphisoft.com/t5/Setup-License-articles/MacOS-12-Monterey/ta-p/309154
The page currently says:
Archicad 25 is compatible from the already available 2nd Update(40xx build).
Archicad 24 will be compatible from its 5th Update (70xx build), which is planned
to be released in February of 2022. Until that please be aware of the known
compatibility issues detailed below.
Laszlo Nagy, Lead Moderator, Community Admin
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
Hello ka,
You should specify your operating system as well as your hardware configuration.
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 25 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2015 - 16Go RAM
Didn't find the answer? Start a new discussion
Labels
