You should not load multiple versions of the Archicad library at the same time.
If you are working in version 23, load the Archicad 23 library and if you need to (because it is an old version file) load the migration libraries as well.
Also I would try not to mix libraries from different language versions.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
