Magic Wand Settings on fills
2raarchitecture
I tried to use the magic wand to create a fill to define elevations better, where this stairs go. I looked it the settings, but I am a bit at a loss. Thank you kindly for any help!
2RA Building Workshop
www.2rabldgworkshop.com
11th Gen Intel(R) Core(TM) i7-11800H @ 2.30GHz. 16.0 GB. NVIDIA GeForce RTX 3060 Laptop GPU.
ArchiCAD 25. 5002 USA Full
1 REPLY 1
The magic wand often fails for filling areas that are a little complex.  You can surround an area with the marque, print as a .pdf, put it back in the drawing with the drawing tool and explode it to get at the fill you want.   ??    But you should not need to do that in order to have that railing display how you want it.
Learn and get certified!
