Make an inserted drawing (.dwg) visible in 3D perspective?
I am wondering how to make an inserted external drawing (.dwg) visible in 3D, in order to build 3D quicker ?
Thanks for your help.
David Maudlin
NGUYEN Tran:
You can open the dwg file as an Object, then save it as an Object, the 2D elements will be converted to 3D (as planar elements). This object can then be placed in the project file as a 3D reference.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
I think this article can help you. In the first steps it talks about saving ArchiCAD content as DWG, but from that point the steps are the same as in your case:
http://www.archicadwiki.com/HowToSuperimpose2dFloorPlanOnto3dModel
Thats helpful. Never thought of that around
