Merge Meshes in 2022
Hi, is it possible to merge meshes in Archicad ? or is still problem continuing ? 😄
I made a model of land and I did extension after. I would like to merge two meshes.
If isn't possible can i get rid of border lines between two meshes at least and keeping curves lines visible?
Skärmavbild 2022-01-17 kl. 15.56.06.jpgSkärmavbild 2022-01-17 kl. 15.56.12.jpg
AC 7 - 27 SWE
iMac (Retina 5K, 27-inch, 2020),
3,6 GHz 10-Core intel Core i9, 64 GB 2667 MHz DDR4, AMD Radeon Pro 5700 XT 16 GB
5 REPLIES 5
Hello Vojtech Slavik,
Do you select your first mesh, click on a peripheral segment, choose the "+" option and finally press the space bar before clicking on the other mesh ?
This method will not merge meshes but will nevertheless make it possible to recover the influence of the second mesh. Otherwise I can advise you to hide the outline of the two meshes and then to redraw in 2D the global outline of the two meshes to create the illusion of a single mesh.
Or you can create a Patch to draw over this line. I agree with you it is not a great solution but you are able to get your aim by this way.
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
"Quality is never an accident ; it's always the result of an intelligent effort" John Ruskin
Thanks Shristophe, this solution make just flat terrain.
It's mean that skip all the curves with highs information.
Any other ideas ?
AC 7 - 27 SWE
Or course my first solution means that skip all the curves with highs information.
Did you consider my second proposition ?
Christophe - FRANCE
I didn't get it second solution. Did you mean like hidening lines by using fills and put above it ?
If is this all possibilities how to reach that how you said both solution is not elegant 😕
AC 7 - 27 SWE
Hidening lines with a patch yes. The line is the problem, hide it !
It's a elegant but not a great professional solution 😉
Christophe - FRANCE
