SOLVED!
Merging Columns in ArhiCAD 25
Mjules
Mentor
Is it still possible to merge columns in Archicad 25? I can't find this option anymore.
Martin Luther Jules
AC 10-27 (Full)
Asus | 64 GB RAM | Windows 11
1 ACCEPTED SOLUTION
Solution
Option >>> Complex Profiles >>> Merge Columns
Martin Luther Jules
AC 10-27 (Full)
9 REPLIES 9
What do you mean.
Merging actual column/post elements or merging columns (output) in schedules?
I see from another post that you actually mean column elements.
Could you merge them before in previous versions?
If so, how did you do it?
I assume it would still be the same method now.
mija
Edit >>> Reshape >>> Merge columns 😊
Archicad 25, build 4013
Montenegro
@Barry Kelly It is not possible anymore, and I don't know why. Please take a look at the enclosed screenshot.
As @mija illustrated it below, the merging column option disappears in Archicad 25.
Martin Luther Jules
AC 10-27 (Full)
This option did not change in Archicad 25 (maybe you were thiking of something else?). Merge columns was always like this. This option makes custom profile for the shape and it can't be complex like yours picture.
I suggest you make it with complex structure in column settings.
Montenegro
Even for simple columns, it doesn't work.
Martin Luther Jules
AC 10-27 (Full)
Solution
Martin Luther Jules
AC 10-27 (Full)
Might be a natural result of the segmentation och beams/columns in 23. I have never merged a column though 🙂
AC 25 SWE Full
This can help speed up work when collaborating with structural engineers on some structural strategies.
Martin Luther Jules
AC 10-27 (Full)
