Mesh - cut plan and lines
Olá,
About the mesh I have two questions:
1 - it continues to be impossible to have the mesh cut plan at floor level right?
2 - May I have the counter line right and the curve levels, or the interiors, dashed? I saw that I can change only the pen from both but I can't change the line type...
May you help me, please?
Regards,
andré calapez
Erwin Edel
You could try making a copy of your mesh (to not lose it) and then convert the mesh to a morph. This allows you to show the terrain (morph) cut related to your floor plan cutplane settings. This also allows you to hide edges if you so desire, though it might be some work to select them all to hide them. Dashed lines should be possible for outlines and cutlines with morph too.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
1 REPLY 1
Erwin Edel
www.leloup.nl
Windows 10 Pro
