Minimal Space - Show for specific doors only
Johann_P
I'm trying to show "minimal space" for certain doors only, and not all the doors & objects in the view.
Any help would be greatly appreciated.
ArchiCAD24 - since Nov 2020
Revit - 2005 to 2020
Windows 10 Pro
2 screens: nvidia quadro RTX 4000
Globally (for all objects), it is controlled in the Model View Options.
But you should find there is a parameter in each object that allows it to use the MVO or not.
Turn it off so it is not using the MVO and you should then be able to control it from the object parameters.
If they have been scripted properly that is.
ricki-fritz
You can make the minimal space for those doors that don't require it shown to be '0' (zero) on all sides, then the minimal space polygon will not appear
Graphisoft Certified ArchiCAD BIM Manager
ArchiCAD 27
Windows 11
