2022-08-16 03:16 AM
Is there a way to easily mirror multiple doors (or windows) in place, around the centerpoint of each individual opening? The mirror command always seems to require an axis, and so you have to do this operation one door at a time.
The closest I can get is rotate and flip, this comes close, but it also changes the reveal side and that brings its own set of problems, at least for exterior walls.
Hopefully I'm just missing something obvious here...
2022-08-16 03:29 AM
As far as I know, you're not missing anything obvious.
2022-08-16 03:41 AM
Well, that's unfortunate but not unexpected.
Another one for the wish list, I guess... 🙄
2022-08-16 04:15 AM - edited 2022-08-16 04:17 AM
Hi @david_skogvold, there’s no frustration as I know you can select all doors you want to mirror at once and make two clicks, 1 to flip via info box or opening the door settings dialogue box & 2 rotate via pressing the middle point of any door then choose rotate from the pet palette, try it.
2022-08-16 05:13 AM
Mahmoud, this works in many cases, however it is not the same as mirroring.
Using this approach the inside / outside of the door is reversed, so for exterior walls and other applications where this matters, you might end up with more work in the end, not less.. see attached example.
BEFORE flip+mirror
AFTER flip+mirror
2022-08-16 09:17 AM
You’re right David it can’t be done without extra work, I think it would be better if you can explain how this task could be achieved simply in order to be a practical wish more than a general one, thx.
2022-08-16 10:45 AM
Well, to my mind, this should be done in one click, just like how Flip or Rotate works. Simply select any number of doors, then Edit>Mirror, and done. Keep an option to input a mirroring plane for the (relatively few) occasions when you need that.
