Missing Library folder
Dali_
Have just upgraded from ArchiCAD v.20 to v.24. I have found that there is a missing folder in the library – namely, 'Fences and Railings'. It should be in Basic Library > Building Structures > Fences and Railings. The folder is completely missing. The folder still exists in AC 20, so it appears that AC 24 is not correctly importing the library migration files.
Does anyone have any idea how to resolve this problem?
The fence and railing objects no longer exist in the new versions (since version 21 I believe).
Loading the migration libraries (for all versions 20-24) should keep the old objects in your file.
We are expected to use the new railing tool now instead of these objects.
Dali_
Thanks Barry for the prompt reply. I did not even realise that there was a 'Railing Tool'; I have only just started using AC 24. I had previously tried loading AC 20 Migration Library, but that didn't make any difference; I will try what you say.
Interestingly, there is also a new 'Equipment Tool' – as I have just found out – that duplicates the kitchen equipment and cabinets that already exist in the Object Tool > Basic Library > Kitchen Cabinets, etc.
Regards.
David Maudlin
That is because the MEP add-on is now part of the standard AC package (it was a separate add-on before), so those objects can be used as part of the MEP functions.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
