Design forum
Missing tool on Archicad
Hello!
My problem is that I have installed the grashopper live-connection with no issue on the instalation whatsoever. but when I look for the tool in archicad it doesn't appear, ive searched for this issue in various post with no sucessfull answer. I'll attach some snaps of places where the button should appear but doesnt. Archicad and Rhino are updated to the date.
PD.: I checked the add-ons folder and the grasshopper connection appears to be installed.
Im runnning:
Rhino 6
Archicad 22 SPA
Win7
12 REPLIES 12
If you go to the "Command Layouts Schemes > Menus" page of the Work Environment Dialog, and in the list of available command, select the "All commands in alphabetical order" option, can you see the "Grasshopper Connection" command in the list of available commands? If you do, you can just add it to your menu structure.
Laszlo Nagy, Lead Moderator, Community Admin
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
i don't see it. sadly.
I am wondering if this is because you installed Rhino 6.
Can you make it work if you install Rhino 5?
I also see that you are using ARCHICAD EDU version. I was wondering if Rhino can be used with the EDU version. I don't have the answer to that question though, maybe someone else does.
Eduardo Rolon
It should work with the EDU version.
eduardo rolón AIA NCARB
Another of the forum moderators.
Macbook Pro 2.4 i9 32GB ram
OS X 10.XX latest
AC25 US/INT -> AC08
Thanks Eduardo for the info.
Im gonna try downgrading to rhino 5. thanks in advance for the answers!
I downgraded to Rhino 5 and same issue. My guess is that is a problem with the Archicad part and not Gh or Rhino. Actually the Archicad tab appears on Gh and i can use the BIM parameters and stuff (still haven't synced anything ovbiously). I have an old macbook pro and it works but my hardware is not good enough to support working fluently with the 3 softwares running without crashing or freezing.
Maybe it has something to do with using de SPA version of Archicad? im gonna try downloading de INT version although i don't have a license key for that, so im going with the trial. do you know if trial version supports it? (weird they use different license keys)
My other guess is that maybe using Win7 is not ideal for the GH connection? just guessing, dont know actually... this is the hardware im using.
Intel i7 4790K CPU 4.00Ghz Win7
16Gb Ram DDR4
Nvidia GeForce GTX 960
I don't know of the SPA version should be a program.
But what I know for sure is that I have a laptop with Windows 7 on it, and AC22 INT works just fine with Grasshopper 5 and the Connection is fine.
Hassib Haidar
Hello Guys,
I am facing the same problem and I was wondering if you found any solution?
Best,
Hassib
Daniel Kovacs
Hello All,
Based on what you say, it seems like the Grasshopper side is perfectly fine, and the problem is with the ARCHICAD side of the Add-on. I would suspect that you might have multiple ARCHICAD versions installed and when the installer ran, it placed the add-on in one version of ARCHICAD, but you are running a different version. Please check the Add-on folder of the ARCHICAD you are running (.../GRAPHISOFT/ARCHICAD 22/Add-Ons/), and see if you have the "Grasshopper-ARCHICAD Live Connection" Add-on in this folder. If not, then the Add-on is installed somewhere else, and you cannot see it in ARCHICAD, because it is not actually there. In this case just find where this ARCHICAD Add-on is, and copy-paste it here.
Let me know if this helped.
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
I'm facing the same problem...
Have someone found a solution?
I'm using the latest version of Archicad 23 and Rhino 6.24. I'm under Windows 7.
Nothing appear in Archicad, but I have all the component in Grasshopper.
Thanks in advance
Clara
If you go to the ARCHICAD installation folder and then go to the Add-Ons folder, you should have a "Grasshopper-ARCHICAD Live Connection" folder in it. The "GrassHopperConnection.apx" file in this folder is the ARCHICAD side of the ARCHICAD-Grasshopper Connection.
Also, if you see these files, then you could check the Add-On Manager Dialog ("View > Add-On Manager" menu command) and see if the "Grasshopper-ARCHICAD Live Connection 2.3" item is there and its checkbox is checked.
Didn't find the answer? Start a new discussion
Labels
