Design forum
Missing window 24 and double sash window 24
iamme
The issue is with a projects files library that a previous coworker was working on. We are working with Archicad 24 and when beginning to work in the file there were many objects missing from their library manager. I was able to update the libraries and retrieve all but two types of windows. Those being the "window 24" and "double sash window 24" you can see they are missing in the drawings. I have tried a few things with updating the build and making sure the libraries are up to date, yet it is not seeming to help.
1 REPLY 1
Are you both working with different language versions of Archicad - INT, USA, etc.
The libraries in each version may have the same name but have different content, especially when it comes to windows and doors.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
Didn't find the answer? Start a new discussion
