Mitered Corner Louver Curtain Wall Panel
marsa15
Hi guys, is there a way to model mitered corner of curtain wall louver panel ? I can't find any setting in curtain wall panel setting and solid component operation also didn't work.
Hello marsa15,
Failing to achieve this with the curtain wall tool, I would use the wall tool with a complex profile + integration of the vertical posts with the railing tool.
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
1 REPLY 1
Hello marsa15,
Christophe - FRANCE
