Design forum
Modify GDL Object Parameters in Grasshoppers
hpenbeoglu
Note: By default, Grasshopper cannot access the internal parameters of ARCHICAD Library Parts - they are grayed out on the interface. To allow Grasshopper to access the Library Part’s internal parameters, you must modify its program code.
Hello everyone,
The quotation is originally written in PDf documentation of GS-AC connection. What does "modifying its program code" means? How can I do this and reach its parameters? Because I want to modify object parameters at GS.
BIM Manager, Architect in the UK | AC11-AC25
Macbook Pro 16" 2.4 GHz 8-Core Intel Core i9 - 32 GB RAM - 512 GB SSD
2 REPLIES 2
hpenbeoglu
I downloaded the new PDF and there is a more detailed explanation of it.
Nader Belal
Mentor
@hpenbeoglu
Hi there,
It means that Grasshopper can't modifiy the parameters' values of ArchiCAD's Library Objects (the same is true to other object's too), unless
you create a specific parameter that tells the program to permit Grasshopper to access the object.
Download the "Grasshopper-ARCHICAD Live Connection 2.2 User Guide" and start reading from page 86
Didn't find the answer? Start a new discussion
Labels
