JGoode:
Use an Add2 command for the initial position. Then before the Text2 command, add 2 movable hotspots (one for x and one for y), then a Add2 command with the movable hotspot parameters. Make the movable hotspots parameters visible in the interface so they can be reset to zero if necessary.
