Design forum
Move Text but also give starting position
JGoode
Hello,
I have some text that needs to start in the middle of a line that changes length which is of course very straight forward. However I need to be able to move the text using hotspots.
So my question is how do I start my hotspots at "line/2" but also have the ability to move it without it being locked down?
Thanks
ArchiCAD 23
Windows 10
1 REPLY 1
David Maudlin
JGoode:
Use an Add2 command for the initial position. Then before the Text2 command, add 2 movable hotspots (one for x and one for y), then a Add2 command with the movable hotspot parameters. Make the movable hotspots parameters visible in the interface so they can be reset to zero if necessary.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC26 USA • iMac 27" 4.0GHz Quad-core i7 | 24 gb ram • MacBook Pro 2.8GHz | 16 gb ram • OSX10.15.7
Didn't find the answer? Start a new discussion
