The elevations and sections use the same origin as your plan.
So if the plan is a long way from the origin, the elevations will be a long way from it as well.
The problem is that when you move the model and the section/elevation lines closer to the origin, you have probably done this by selecting it all (or use the all storey marquee if there are multiple storeys).
So in plan the model and annotation is all being moved together at the same time.
In section/elevation, the annotation is not linked to the model, and because you can’t select it from the plan view, it won’t move and stays where it was in relation to the origin.
With the exception of associated dimensions, the witness lines will stretch to stay linked to the model.
Unfortunately you have to move the annotation in each elevation separately to agin match the model.
Likewise if you move the model in 3D window, I think you will find the floor plan annotation will not move (except dimension witness lines will stretch again).
Also beware of info in layers that were turned of during the move.
That info won’t move either.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
