Goodmorning forum!
I was wondering if anyone found/created an object that kind of combine all the electrical switches,such as 1-pole, 2-pole, dimmer, etc.
So you can have a one-size-fits-all, per se, switch for placement, listings etc.
If not, any ideas on how we can make it happen?
On the top of my head, the main problem that need to be solved is creating a drop down menu that let you select the type you want and change the 2d symbol accordingly.
