Multi-plane roof planes disappear
RF
I keep having this issue where roof planes disappear whenever I try to adjust the nodes of a multi-plane roof. Sometimes the roof disappears altogether. The missing plane is set to pitched, not gable, so it must be something else.
Tried this in both AC 25 and 26, same issue.
Intel(R) Core(TM) i7-10750H CPU @ 2.60GHz 2.59 GHz 32GB RAM
Intel(R) UHD Graphics 128MB VRAM
Windows 10
Thank you
Actually I figured out the issue. I was modelling based on a cad drawing I had imported at the wrong scale. What I though were millimeters were in fact meters so the roof was acting strange due to the x1000 scale. Works fine at 1:1 scale.
Sometimes It's the mistake you'd never expect you'll do...
Thank you
It looks like there is a double hotspot in the corner of the section of roof that has disappeared at both ends. have you accidentally inverted it?
Lee Hankins
ArchiCAD 4.5 - Archicad 27UKI Apple Silicon 27.2.0
macOS Sonoma (14.4.1)
Thank you
