(NEW TO ARCHICAD) Can ArchiCad do a Similar function like this?
Can ArchiCad do a Similar Function like this or A different Function but achieve the same results?
6 REPLIES 6
Form what I can see, sure. That can be modeled with ArchiCAD easy enough.
is there a command that lets you place Multiple... Custom Windows or Objects on a massing faces all at once?
You can copy windows and door with muliply function and it's so easy.
But if you want more control specially if you need non-one size windows you should usw grasshopper-archicad connection
My answer is just guide line but you should learn the essential order in Archicad
Good luck.
I can imagine you could model those custom units using Morphs, then save them as custom Curtain Wall Panels.
Then you could place a Curtain Wall, go to Edit Mode, and change a series of Panels to one of these custom Curtain Wall Panels, then repeat for all other custom Panel types.
DGSketcher
Legend
It would be a lot easier if we had an in-place module editor...
There is always the Wish forum.
