Need help for wall label
Palawat
Hi everyone,
I'm working on a label (ArchiCad 17) for wall and need to know the Reference Line Location and Length of the Reference Line of the wall, so that I can place my label correctly. Is there a way to do that?
I know that REQUEST ("ASSOCLP_PARVALUE", expr, name_or_index, type, flags, dim1, dim2, p_values) exists, but I don't know what to put in "expr", or even if this is the right approach.
Thank you in advance
Archicad 26, Windows 10, Corei7 3.4 GHz, 16 GB Ram.
https://www.indigofigs.com
https://www.facebook.com/indigofigs
2 REPLIES 2
Hi Palawat,
currently this cannot be done.
First of you are trying to use the code for extracting the info of an object-parameter, not a wall parameter.
Second, you can use the Globals 'Wall parameters - available for Doors/Windows, listing and labels' such as WALL_THICKNESS.
However WALL_REFLINE_OFFSET does not exist (BEAM_REFLINE_OFFSET does). This has been requested at Graphisoft.
Palawat
Thank you very much, Master Script.
I'm relatively new to GDL. Getting answer from the professional is very helpful.
Learn and get certified!
